Given up on The DeltaQ
Three different barcodes for you.
Disc brakes in the front, drum in the rear.
Would you like to steal it? Please.
I’ve always wanted bigger tires. Maybe still do.
I’m sorry, are we talking about your wife or the car now?
…badaump…thiisss…
613-00249 is the 10.35:1
Late 2004 manufacturing tag, yeah, this is that GEM “fast and loose” with the parts I mentioned. Or someone swapped it. The VIN sticker on the roof of the cab should have the date of manufacture on it somewhere. Be curious to find out that date.
Controller is the T3
The motor sticker is the wiring. Would need to see the other sticker or other half of that sticker. Likely a short ge 5hp from the pictures.
Yeah, I get it. it’s not easy to drop another $2500 on a new Lithium battery but if taken care of properly it will be the last one you buy. The car will be lighter, peppier, and have double the range. Besides, you were saved from getting that 6 bank charger so it will be only like 1650 more. I’m not even sure where that beast would fit?
Add a new set of styling bigger wheels and that car will get you up to ~33.
OBO on either…Serious inquiries only…
Hi I’m searching for a few green 60Ah phosphate cells I believe you obtained from inwo? Working on a robot mower and found a bad cell… I’m struggling with navigating this site so please contact me at (507) 951-4615 thanks
Pinging @JarJarJava, he has some.
Hi, Dave told me about the bad cell the the other day. Not a problem, I just have to test a few. My weekdays are typically shot, but I’ll give you a call in a bit. (You’re a few hours ahead, I’m in CA, still almost early here)
They have all been tested previously. If they don’t self discharge quickly and take a charge in a group ok, they should be fine.
Don’t forget that I have balance boards for them left at $5 each.
Also if you come out ok after shipping I would like a piece of the action on the “ammo case” battery. That is the only one that had any value to me,
If you lose your butt after paying transportation cost, sell that one to recoup your losses. No matter to me. I have bigger fish to fry. :slight_smile:
Where is the 2005 E2 located?
DO NOT GIVE UP THE DELTAQ DO NOT GO TO QUICK CHARGE.
Your problem is you have 1 or more batteries with bad cell/s , DO THIS.
charge the pack.
note each battery voltage.
Drive until cart slows down
imwdiately read each battery
you will have 1 or more reading only 10 volts thats the dud.
I believe he is out in Az. I’ll scroll back and see if I can find it.
That was what I meant, I guess I should have said “check” rather than “test”. @Rcon already worked something out with LG by the time my side of the country got moving this morning, so I think everything is good there.
Not that it would have made a difference, but I didn’t realize this wasn’t for a GEM. It’s a DIY self-driving lawnmower that he built and wrote the software for. It runs around like a roomba mulching the lawn automatically and even has a 320W solar panel on it for self-recharging. Sent me a couple photos, super cool,
I literally have not looked at the lfp cells since George dropped them off and first time putting a meter on any of them was while I was on the phone Doug. Things have been 10-11 hours every day at work for a few weeks now between capex projects, OSHA and emergencies.
Has George dropped the boxes back off yet? Or is he still out on the road?
Today sometime, I hope.
Cool. He should have a few things for you - boxes, old battery tray,
Here is my best shot at getting the rest of the label on the motor for and the vin.
Green Valley Arizona, 20 miles south of Tucson…
Was a block from home earlier today and the motor clunked a couple times and died, burned electrical smell.
Thinking the price just went down. Bummed.
