Barbjb@acegroup.cc
Chargery products bms
5078944754
Ebay contact info barbjb
If you have a dead DQ charger and want to take a chance on getting a cheap repair, I’ll give it a try for $100 plus shipping.
Pay nothing. Send it to me.
If I fix it, pay $100 plus shipping back.
If I don’t, pay for return shipping or not.
Or I’ll ship it to Rodney for rebuilding.
I can also add one of these profiles, if it’s a programmable model.
One time deal, I’m not starting a new business. Want to see how it goes.
I maybe having a problem with the DeltaQ charger on a 2000 GEM that I have. It does all kinds of crazy things when I plug in the charger with beeping and light flashes. I discovered that one of the Trojans installed has a cell with the electrolyte below the plates. I picked up a replacement battery and with see how the charger performs after I install the new battery.
It will do that with battery problem or wrong profile. I haven’t seen any with problems, that weren’t dead of flashing error code.
If you need a DQ charger, I may be able to help.
[quote=Inwo;33532]It will do that with battery problem or wrong profile. I haven’t seen any with problems, that weren’t dead of flashing error code.
If you need a DQ charger, I may be able to help.[/quote]
I replaced the bad battery with a new Trojan that I picked up. I charged all six batteries with a 12V charger. I plugged in the DeltaQ and after the self check of the lights it fast flashes 6 times and never starts charging. I unplugged the DeltaQ, checked all the connections and tried again; same results.
I finally took the time to check the continuity between the red and green wires that come from the DeltaQ charger. Less than an ohm resistance. The green wire is not connected to anything; should it be?
The white wire connects to black thru temperature sensor.
Check sensor with ohmmeter. Sensor should be connected to battery post and look like large a wire terminal.
The last check that I can think of is to connect charger direct to battery, with good sensor connected.
Keep green taped off so it doesn’t short and blow fuse.
Dumb question. Does any one have experience where the heat sensor actually triggered on a DQ or Zivan charger? These puppy’s are only 12 Amps Charging 95 to 150 AH battery banks.
