Throttle repair now available, 45 day Warranty.
I can have my gogo stick touched by Rodney?
Raarwh!
Have you found a source for parts or rob them from a similar new automotive pedal?
No. Went another route.
Ship to me with return shipper. 3 day turnaround.
I might need it done on my '10eL. I have to get time to debug, see if the occasional error (45 iirc) is the pedal or a programming thing.
What is the cost?
You ship to me with a return shipper.If it’s repairable i fix and return with in 3 days. No charge if I cant repair. Requirements Under 5000 miles - never been submerged - never been opened. At this point in time $125. 45 day money back warranty.
Sure no problem
Diehl Engineering
2400 Baywater road
Tavares
Florida
251 269 3182
No email reply from you. Check your spam.
@JarJarJava not in the refrigerator!
@AssyRequired Check you junk box for anything throttle. Somewhere was new guts for one and a troublesome internal micro-switch sample. You may have given it away by now.
Rodney wants to run with this, but plenty business for all if you are still “in”.
I’m sending a Saturn, electronic switch spoof, and an led tester.
Spooif device has never been on a Gem and maybe 75% that it works at all. 50% that it will be useful long term.
The led tester is nice. Feel free to copy it. It takes a while to source parts and put it together, but I may part with it if you kiss up to me properly. ![]()
send to
RODNEY DIEHL
2400 BAYWATER
TAVARES fL
32778
I need failed pedals 5000 MILES OR LESS NEVER OPENED!!!
At this point in time switch is a slam dunk. The main criteria is full throttle resistance. If off, top speed is drastically reduced.
