Scowl up, there’s a diagram showing what each wire is for. On the harness side Orange/Black is 72v ground, Orange/Gray is 72v positive, Green is interlock, if you want to bypass the interlock run the green wire to 72v ground (do not put any power on the green wire as it will fry a resistor in the instrument cluster)
