Here’s another question, and some experience behind it. Again, the car is a 2013 smart electric coupe.
The car comes with a charger that plugs into a normal 110 volt household receptacle. There is one in the in-house garage. The user’s manual says that there should be nothing else on the circuit. There isn’t. According to the breaker in the junction box the circuit is rated at 15 amps. So far so good. However the cord on the charger is not long enough to let me park where I want in the garage and charge the car. In fact to do so would be very inconvenient.
The manual states clearly that using an extension cord is a no-no. I tried it anyway with an old but heavy duty extension cord. The plug got kind of warm, and the car stopped charging. The charger must be smart, because nothing was damaged. I then bit the bullet and parked the car next to the outlet (after moving a lot of stuff around). No problem, charged as expected.
Then, looking through the car’s menus, I found that I could limit the amps that the charger would draw from the default of “MAX” to 12 or 8 amps. I tried it at 12 amps, and there was no problem using the extension cord.
Then I bought a new extension cord rated at 15 amps (same as the circuit I’m plugging it in to) and with 12 gauge wire (heaviest you can get). I have charged the car with the setting at 12 amps and “MAX” amps. No problems and nothing getting even slightly warm. I throttled it back to 12 amps just to be on the safe side anyway. Given the miles we drive in a day it will have plenty of time to charge overnight at that setting.
Does anyone have any thoughts on/experience with all of this? Before you answer, let me say that one thing I will not do, at least at this juncture, is rewire the garage for this purpose. The junction box is at exactly the opposite corner of the building from where I want the charger. This would not be cheap. If we really get into electric vehicles (I’ve only had this thing 3 days) then we might do it really right and run a 220 line all the way over and get a faster charger. But that will be after we have the car a while, see how it does in a New England Winter, and if it fits our lifestyle as well as I think it will.
