Hey guys. I have a 2005 GEM EL and the past 2 mornings I’ll be driving it and while I’m at 25 mph I’ll get error code 11 (drive petal engaged while turning on the key). Now since I’m not turning the key while I’m driving obviously I shouldnt be getting this message. Any ideas? Is it overheating of the motor or possibly a short of some sort? Thank you
Also I think it has to do with going over bumps. They’re just regular bumps on a flat road do its not like I’m getting any air or anything.
Usually code 011 is the result of a foreign object stuck under the pedal. Less likely is an electrical glitch in the pedal components or the wiring leading to the controller. If the 72 volt power to the controller is interrupted for even a fraction of a second, the controller resets and looks for a closed throttle before allowing power to be applied. This is intended to prevent the vehicle from “taking off” if the throttle becomes stuck.
Check for the obvious. A big one for us has been a cord used for charging that gets under the pedal. Next, look for any loose connections in the 72 volt power circuit. If you get the code 011 only when going over bumps, this is a strong indicator of loose wiring. Do not try to bypass this or any other safety device.
Daniel
I have the same error 11 problem, 2001, I replaced the potentiometer (sp ?) in the pedal, that did not fix the error problem so don’t try that. I will look again at all the connections, about two weeks ago I got another opinion as to what is the root of the issue and was told it is in the batteries. I am still not convinced of that thought,
will continue looking and see what turns up if anything.
@daniel When you’re talking about something being stuck under the pedal you’re talking about something just on the floorboard right? I don’t have anything on the floor. I looked around under the hood and didn’t find any loose connections.
[QUOTE=Brains530;12405]@daniel When you’re talking about something being stuck under the pedal you’re talking about something just on the floorboard right? I don’t have anything on the floor. I looked around under the hood and didn’t find any loose connections.[/QUOTE]
On my car, when I look, there is nothing under the pedal but I continue to get the infrequent 11 error code, i took the foot pedal apart and looked inside the pedal and found nothing stuck in the way, i did replace the potentiometer thinking that could be the problem, the pot. is in the foot pedal , but that did not stop the error 11, still confused and looking myself as to the fix.
I have also had the #11 error. I spent a lot of time inspecting the foot switch, cleaning, lubing, etc. I have not experienced it since I began “slamming” the parking brake off. I think gently releasing the lever left the microswitch “on the fence” and any small jar would set the error code.
Eric
[QUOTE=ewagnr;13152]I have also had the #11 error. I spent a lot of time inspecting the foot switch, cleaning, lubing, etc. I have not experienced it since I began “slamming” the parking brake off. I think gently releasing the lever left the microswitch “on the fence” and any small jar would set the error code.
Eric[/QUOTE]
I also have to drop my parking brake very positively to make the switch close.
The heavy rubber floor mat often works its way under the pedal. Also, check the wiring leading up from the throttle. We have had a wire overheat at the connector. Look for brown marks on the white plastic connector.
The parking brake reed switch can be adjusted so that it stays open when going over bumps. This is a common problem.
Daniel
[QUOTE=GEMmechanic;13267]The heavy rubber floor mat often works its way under the pedal. Also, check the wiring leading up from the throttle. We have had a wire overheat at the connector. Look for brown marks on the white plastic connector.
Daniel[/QUOTE]
Did anyone have success? I have the same problem, but worse. The motor stops within seconds after putting the pedal down.
Thanks, Greg
I am having same problem replaced pedal with brand new one & still not working still getting 11 code !!! please help.
[quote=jesse2001e825;12404]I have the same error 11 problem, 2001, I replaced the potentiometer (sp ?) in the pedal, that did not fix the error problem so don’t try that. I will look again at all the connections, about two weeks ago I got another opinion as to what is the root of the issue and was told it is in the batteries. I am still not convinced of that thought,
will continue looking and see what turns up if anything.[/quote]
what did it end up being?
POSSIBLE CAUSE
Start switch is mis-adjusted or defective.
Input voltage at P3 should be less than 50%
of battery volts at key switch closure. Adjust
or replace accelerator unit to insure that the
voltage at P3 is less than 50% of battery volts
before closing the start switch.
Short circuit between P15 and P3 in start switch
input circuit.
Disconnect wire from P3. Check for short
circuit from this wire to 12V positive.
Resistance should be greater than 4.7K
ohms.
Defective control.
Disconnect wire from P3. Measure voltage
from P3 to negative. Voltage should be zero
I keep getting code 11 replaced pedal with brand new one & still getting code 11 any ideas?? please help?
Getting an occasional code 11 while driving 2003 E825, 4 seater. There are several actions that trigger the error. If I’m driving along at full throttle and turn on the lights, code 11. Flipping the blinker on or off, code 11. Sometimes just driving along, code 11. If I lift the pedal and immediately reapply throttle, it takes right off.
I know this has been a while since this thread, but wondering if you found the fix years ago. Mine is doing the same… I run fine up until about 25 mph in road mode, then error 11. It can usually rest for about five minutes then return to normal driving , but this last time it happened, it did not come back to life. Turf mode runs fine and anything under the 25mph. Traced all wires from the accelerator, cleaned all connections.
Thank you,
Jimmy - 2002 e825 two seater
I’m no expert on the GEMs but from what everyone is saying about it happening while going at speed it seems to be the peddle has nothing to do with it… I could be wrong… but it sounds more like bad contacts of some sort and the bounce makes it show. I would replace or jumper the key switch to see if it still happens.
Hey there, I’m getting the -11 code also. I ohmed the hand brake switch, put a fuse between the 2 top wires. When I press the pedal it try’s to go then stops & throws the 11 code. Help me please.
I assume you are working on a pre-2005 GEM. The microswitch used in the Line Master control pedal functions as a “proving” switch. Whenever forward or reverse is selected, the controller first looks for the following:
The parking brake is fully released. (to prevent damage to the rear brakes and overloading of the motor/controller)
The throttle pedal SPDT microswitch is released. (to prevent dangerous, uncontrolled runaway)
Every time the motor controller is powered up through the key switch, its logic must see a “released throttle” signal from the pedal microswitch. Stepping on the pedal causes the microswitch to reverse to an “applied throttle” signal. Once the controller logic sees the microswitch reverse, the main contactor is then allowed to close to send power to the motor. I am using so much detail to emphasize the safety implications of a runaway electric vehicle.
What usually happens on the pre-2005 gem to cause a -11 code is something, usually those thick black rubber floor mats getting under the pedal, causing it to stick in the “applied throttle” position. Just enough to reverse the microswitch, but not enough to send power to the motor. Next time the operator turns the key, the controller sees “throttle applied” and locks out the circuit to prevent runaway.
The other, more annoying way a pre-2005 GEM gets the -11 code is through the parking brake microswitch. A loose parking brake handle caused by worn hardware, frozen brake cables, or misadjusted rear brakes will cause the loose handle to bounce freely with every bump while driving. If the parking brake microswitch opens for even a fraction of a second, the motor controller resets and will see “throttle applied” from the foot pedal because the operator is still holding it down. Getting the switch adjusted properly takes some practice. 2005 and newer GEMs do not have that switch.
Always raise the drive wheels when working on any electric vehicle when diagnosing a drivability issue. I speak from experience here, having seen a GEM crash into the shop wall because the spring inside the throttle pedal broke. It has been a few years since I last worked on GEMs. Hope all this detail is of help.
Daniel
Hi djj - welcome to the group.
As GEMmech noted (also elsewhere in this topic), code -11 is a tricky one to diagnose as it is more of a secondary result/condition code but not necessarily a primary cause/fault. In other words- it is important that you observe WHEN the code -11 appears to properly diagnose and correct the issue.
(Roughly translated) The error more/less reads:
-11 - Pedal found depressed during motor controller boot up routine.
To clear, Lift pedal, -11 should clear, and press pedal to go again.
Talk to it with reassuring words. Try to cheer it up.
The trick is to determine what caused the controller to go into it’s boot up routine.
Three common things (that I know of) will do this.
- Pedal not all the way up when KeyON.
– Check floor mat or contaminants/debris jamming up the works - Handbrake switch loop opening during run.
– Mis-adjusted/sensitive switch or loose wire
→ Bypass switch to test ← Which you did - Momentary KeyOff/On event
– Sensitive KeySwitch or loose wiring
– large cluster of keys on your ring
→ Bypass KeySwitch to check
