I have been wanting to build an unique bike for the longest time now but i have not had the best of luck. I originally build an 2 wheel bike with an 10hp diesel changfa motor from ebay attached to an comet clutch but the bike wasnt very drivable. When i geared it to run 70mph top speed it road icredible slow off the line taking nearly 25 seconds to get to 70mph. I have been reading alot on the chevy volt and i like how its an all electric car with an generator setup for recharging the batterys for long range. I got this new idea from my new vegetable oil generator i have been running for a while now. I have been running the 10hp diesel changfa engine attached to 2 cheap alternators i bought from autozone which have lifetime warranty. there 140 amp alternators and i have been running the generator attached to 6 batterys with the alternator charging 3 a peace and running stuff in the shop to test it i have seen draws of 100 amps at times off the alternators to charge the batterys and the little diesel engine just kept on going like an champ.
Im wanderings if I could build an trike… 2 wheels up front and 1 in the rear motorcycle with the 10 hp engine hooked up in the same manner to charge the 72 volt bank of 6 batterys to power an electric motor to make an electric motorcycle. The batterys would make an short range and the motorcycle would in theory be able to run on just electric for short trips or could start the diesel motor and allow the alternator to hold a charge to the battery bank while allowing juice for the motor to perform… Im not sure how well this theory would work in all but think the diesel generator is rater at 10hp/27tq @ 3600 rpms so i figured if i ran the engine around max torque when its running that would be the best…
