need hep finding a spring clip for the differential spline that holds the cv half axle on for a 2000 E825 GEM car.
The axles are quite inexpensive from NEV Accessories. If you buy a spare, you can always transfer the clip and reuse this shaft whenever the next one fails. I don’t believe these clips are sold separately. The EZ-GO ST 4X4 uses the same inner CV joints.
Daniel
