I do them for $75 .$250 Wow , I should raise my prices .
sorry for the confusion . I reprogram them for $75 . Need to check on the #42 algo . Which model battery do you have ?
I have a 913-4810-E3B charger, and I just bought Bright Way Group 110AH BW121100IT AGM batteries:
Did you ever find if you could do the #42 algo?
I’m sure he can. It’s available for down load
Discover agm.
Thundervolt , sorry for not getting back to you quicker . If you have an original Gem charger you cant add other profiles in to it unless you wipe out the proprietary Gem ones and put in the regular Deltaq profiles . This is what we do for lithium . But the lithium software doesn’t work with lead so I need to see which sw version works for lead so it will except #42 .
I have the sw and algo you want . I can put multiple algos in so you have flexibility down the road
Thank you, sorry about the delay I had to delete a post and wait for it to clear since I can’t have more than 3 posts per thread and can’t send IM’s. Could you please email me at Bric.atwood@gmail? Thanks again.
