I have a 2005 Gem E4 with the original Gel batteries with the Delta Q charger.Can this charger also charge the AGM batteries?
[QUOTE=DMax;9258]I have a 2005 Gem E4 with the original Gel batteries with the Delta Q charger.Can this charger also charge the AGM batteries?[/QUOTE]
Each type of battery chemistry requires a differant algorithm for the proper charging cycle. You can get the algorithms and programmer from various sources at around $200. PM me if you want a source.
