2005…e2. Under the trunk is a cover for rear battery access. It’s held on by plastic screws screwed into plastic hole inserts. Anybody found a way to reattach the cover…like drywall anchors or such.
I use 3 anchors that came with it without the screw and only one anchor with a screw. It was tough to get out and I haven’t had any issues with it popping off with that method of attachment.
How about some Velcro
Get plastic push in automotive trim retainers. Any automotive supply.
i put 4 little velcro squares on all of my gem covers . those factory anchors suck . easy to get on and off and they stay well attached .
@Bolanger I epoxied “Speed nuts” to the bottom side of the Spat like these
https://www.homedepot.com/p/Everbilt-8-32-Plain-Steel-Flat-Type-Speed-Nut-2-per-Pack-800108/204274186
This is the fastener I use for all my battery installs.
