Ok we are talking about 2016+ cars Correct ok cool! Whats been reported as a problem
By myself and others In the past is the wiper motor stay ON. Constantly running you can’t turn it off. (Only solution is to remove the fuse) here is the thread from 2020 that I started.
That reminds me if you remove the fuse and let it sit for a while you can replace the fuse and the wiper will work. It will remain stopped UNTILL you turn it on again with the wiper switch It will just run constantly as it did b4.
So I’ll dive back into the previous thread.
BUT what got my interest peaked is “assembly required’s” drawing of the wiper motor and the possibility that you could adjust the sweep of the wiper motor. That would be a cool Hack if you could. Bend the factory Arm to closely resemble a 2024 wiper arm and advance the sweep. That would be Sweet! We must investagate. Here is a photo of a 2024 Gem. With the wiper arm in the resting position
