I put new batteries in and when I plugged in my charge meter blinks across but my display on how full the battery is always shows 00
Have un hooked all plugs and batteries and reconnected and still the same.
I have a 2009 E2 Gem
Any ideas
John
Did you measure total voltage? Is polarity correct? Does the car run? Sequence ok?
[quote=OLD HOUSEBOATER;24607]Did you measure total voltage? Is polarity correct? Does the car run? Sequence ok?[/quote] I did the polarity is right and the voltage is 75 drove it last night ran fine. I think it went bad last fall and I didn’t notice it all batteries were completely dead this spring. Charge indicator on percentage doesn’t register and it is in full charge all the time.
If you charged the batteries fully and only took a short trip the voltage probably didn’t drop below 76.44 volts. At full charge off the charger you may have started out over 80 volts. Take a longer drive.
