Guys need help here. Whenever I go to charge my battery’s I get an alarm that goes off and it doesn’t charge. I’ve turned off switch for 90 seconds to reset. And nothing. Alarm comes back on. I’ve charged the battery manually one by one and still doesn’t run. Can anyone help me with this matter.
Probably make it easier if we knew what year gem, what charger, which batteries,what color the gem is and pancakes or waffles?
I’m sorry about this.
I have a 2002 E825 2 seater. The battery charger on that is a Zivan NG1
What color and state (blinking / solid) is the 3 color LED above the spedometer and how many beeps or is it a long continuious beep?
How old and what type of batteries?
To expand on what JarJar is describing,
Your charger will produce a two tone beep when it has an issue. Then it will flash the LED on the dash. The colors it is flashing will tell you what the problem is.
Thank you very much for your help on this issue. The chart really helped out. Greatly appreciate that
