I received my GE T2 controller programming kit from http://home.paonline.com/rmeyer32/nevprogramkits.html today and read the 2002 GEM eL controller’s factory programming into the database. I then made the following changes. I’m sure it’s just a first step but I don’t see these as too drastic.
Function # .Description. . . . . . Original … Modified …Results
… 02 . . . . . Creep Speed . . . . . . 205 . . . . . 170 . . . Reduced minimum duty-cycle to 5% to reduce jerky starts (was 10%)
… 03 . . . . . Contr. Accel. . . . . . . . . 20 . . . . . . 12 . . . Quicker off the line, less delay
… 06 . . . . . Arm. Accel. . . . . . . . . . 60 . . . . . . 29 . . . Reduce Turf accel to 2.5s (might reduce even further)
… 07 . . . . . Min Field Current . . . . 85 . . . . . . 73 . . . Max motor speed increased (Caution: Could damage stock motor)
… 08 . . . . . Max Field Current . . . 241 . . . . . 251 . . . Increased max torque for better hill-climbing
… 11 . . . . . Turf Speed Limit . . . . 122 . . . . . 128 . . . Turf limit about 22 MPH
… 12 . . . . . Reverse Speed Lmt …144 . . . . . 155 . . . Reverse about 12-15 MPH
… 20 . . . . . MPH Overspeed . . . . . 28 . . . . . . 33 . . . Speed limit about 30-31 before regen starts down-hill
My 2002 eL has 12 inch wheels/tires. These settings improved the eL’s top speed, acceleration and turf-mode drivability. Your settings may differ and change them at your own risk.
I drove around up and down hills for about 5-10 miles with a stop for supper and noticed nothing abnormal other than much higher speeds. I still get regenerative braking and charging pedal-up going down steep hills and I suppose I’d get some if I exceeded the 33 MPH limit I set but that’s plenty fast enough in the little GEM. On our pot-holed streets I’m often well below 20 MPH in some spots. These settings generate some extra heat in the motor so I’ll be wrapping it with aluminum fins soon and maybe adding a blower or air duct to direct more air at the motor.
