Bad terminology on my end lol
Forget the terminology, Can you describe what it feels like with a bit more detail?
It sounds like you narrowed down a solution by not applying as much throttle when conditions exist (this may be a clue).
Does the 2018 car have a low(turf) setting you can flip to just to compare notes and for future programming target?
2016+s don’t have a turf mode.
If I understood correctly, it will cavitate or jerk, at low speeds when you smash the pedal. in my opinion the motor can’t keep up with the power that speed controller is giving and it goes out of syncro.
Options are:
-don’t hammer the pedal.
-Reduce the Torque request a lower rpm. (Probably from 0 - 2000 rpm )
as Dave says, not sure if it can be done with oem controller
I’ll see if I can capture it on video tomorrow.
