Is it noisy ??? You do not have to run it wide open all the time but you have speed when you need it Just ordered kit 2 for my 2016 E4 hope to see that number
It sounds like you proved R4F wrong (It wont work?)
How is the accel on the bottom end?
Having 6 people loaded up might be a little doggy when taking off.
If you live around any hills makes the problem a little worse.
This is probably why R4F says it won’t work.
Maybe you can trade your gearbox for someone that installed a Kit 1 and wants to go faster?
i had the #1 gear installed in my 22 E4, it does 34 mph (radar) which is plenty fast enough, for the disk brakes that are not that good. it has the 6.5 kw motor. considering the steering, etc, i wouldn’t want to go any faster.
With 6.5kw motor and heat sink on controller you should be fine unless needing more torque. Ie. @AssyRequired
Motors are temperature protected, overheat symptoms will be fault and loss of power.
(See Inwo comment above)
You are in a lucky position to test.
If the motor is overloaded it will tell you before burning itself up.
You may need a finned heat sink under controller if that gets hot.
A LWB 6 seat car has the added advantage of length and more stability for the higher speeds once you got there.
How is the performance down at low speeds and loaded with friends?
Do you have the roads to support it and a need to go that fast?
I’m going to have to send Ride4Fun a Christmas card. They sell people gears, range drops hard and then I get to sell them a lithium battery. Yes speed sucks power. No lead battery will keep up with a 35mph Gem for long. FYI the lithium will be 250 pounds lighter so will help with acceleration a lot. Also we can raise the voltage 4 volts to help the motor.
The top end is really nice, I roll into the throttle until about 15 mph to avoid wheel hop
You should be fine, the only time i notice issues is if I’m going up a really steep parking ramp loaded with people. My cart is completely stock otherwise.
By wheel hop you mean “jerking”? As I don’t believe there is enough power to the wheels to actually hop.
It may be possible to tune that out. Some of our conversions have this issue and we do not consider it acceptable. A possible reason high gears were ill-advised by seller.
Wheel hop-
My brain translated that into “wheel spin”. I would have thought that going higher ratio would make it worse.
Now that the scene (loaded with passengers and going up a parking ramp) was laid out this sounds like it is something else like low speed cogging? (The motor not keeping up with the AC Pulses).
