GEM stalls randomly for a few seconds. Lately I turn key to off and wait a few seconds and starts again. Checked all battery connections all tight and clean. Also checked the connection from controller to motor and retighten the connections. I noticed that the charger warning light intermittently flashes. I use the GEM almost everyday for trips around the neighborhood and always place to charge overnight.
Key switch failure is common.
Does 11 code flash when it stalls?
Is there a way to check.
No code just goes blank.
Our sympathy’s You are the unfortunate owner of an intermittent bad/broken connection joint or switch. You have been given the opportunity to shake a lot of wires, jiggle a lot of terminals, practice and maybe increase your vocabulary of colorful expletives and in the end be a better man for the exercise.
Start with the parking brake switch and connections and go from there. Be sure to get back with us when you find it.
I had this situation on my present build. In the end i had to change the complete harness.
In a message dated 3/18/2020 9:38:37 PM Eastern Standard Time, electricforum@discoursemail.com writes:
Remove any extra keys on ring. See if switch is touchy when motoring.
Hi
if car stall you have sound from parking brake summer ?
or totally dead ?
can be your dc/dc have problem,maybe water inside charger will get that problem
Yes there is still sound similar when you take key out and don’t lift the parking brake.
ok it can be a key problem
