Helping a friend do a lithium upgrade to his 2014. He tore out the Delta Q to have the algo changed but didnt label his wires. Charger is back in and Im completely at a loss where the Green Interlock wire goes. It has a male spade and there is nothing within reach of the wire to even attach to.
Anyone have an idea? Diagram shows it going to the PSDM.
Thanks Mike, I saw an earlier post of yours and was going to DM you.
The harness plugs into the PSDM, off that is a black with a ring, I’m guessing that is a 12v ground, right to the frame.
The red I have right now going to PSDM 72+, black to PSDM 72-. I can easily put that to the controller pos and neg. I have to check the profile Dave put in, if I remember it’s the 98v.
It all changed with the Lithium profile on the charger - Ignore the orange and orange/black wires now.
White needs to be -72v grounded, you can do that from the charger black wire or any other -72 source.
The green wire in the harness of the GEM can go to any +72v source or I guess the green wire from the charger can connect to the green wire in the harness as @Inwo has said, but I have always just hooked it straight to +72v and capped off the green wire coming from the charger.
If the car runs it’s fine. If not it needs +72v from charger.
The one Mike runs to B+72v normally gets power from charger.
Then car doesn’t run when plugged in to ac.
Dave, thats what Im thinking, but I cant find it! The connector (male spade) on the green doesnt have a mark on it, so Im thinking it must not be used.
