had 6 wires into J4 (two White, 1 Red, 1 Green, 2 Black.
A new/used/refurbished PDSM and Delta-Q QuiQ 912-7200 with only 4 output wires (1 White, 1 Black, 1 Red, 1 Green no P4 connector) was purchased but I have no pin out for the harness end where P4 is to be attached so it can be connected to PDSM J5.
Yes, you need a dci type charger. That plug supplies all of the 12v systems.
Save the old charger, as some of us can supply you with a new generic dci charger. We need the plug from old charger to make the new one plug and play.
A new Gem branded charger may be hard to source, and possibly cost $750+, if you do find one.
But my concern goes deeper. I think you might have a handful in front of you.
What is the history of this car?
What does the other car look like?
This car sure looks like a flood car. Can you post more pics?
Is that a water line that continues all the way around at other points on the perimeter?
If it is what I think it is, you will have nothing but issues here. Beyond the entire electrical system, Any and ALL fasteners will be a challenge to remove. To get an idea what you will be in for, try to take a wheel off. How hard is it to get the lugs off? Do this to a front wheel and get a look at the brakes(check the back too).
In future, you may never get the axles out of the front hubs.
Do the wheels roll smoothly without much effort?
First of all, welcome to this great forum-there’s a lot of cumulative knowledge here.
@AssyRequired makes some good points. If that indeed is a ‘high water mark"‘ you may bite off more than you can chew(no insult intended). Is your intent to make both of them run? You may have to cannibalize one to fix the other.
As inwo said, you need a different charger. The correct Deltaq for your year has trhe 12v converter built in that plugs into the psdm. New they are 1200. If you have the old charger I can use the cables to get you a new correct charger for half what the dealer charges. flooded Gems are a real challenge.
The e6 was completely stripped down. Wiring harness removed and each wire rung out and checked good. Axle, brakes, motor suspension all RnR’d. Electronics replaced with like for like parts. The only piece in question is the pin out of P4 since I didn’t want to start randomly trying to wire the connector hoping I didn’t fry the new components. Removing parts was no issue with bolts, screws etc.
We purchased the DeltaQ with the DC/DC converter having 12vDC out. It only has 4 wires at the output and the wiring difference between the 4 wire output and the P4 6 wire using two white and two black are the point of confusion. Perhaps the two white wires were tied together and one black to chassis?
I updated my post to answer the water issue. Thank you for providing the photo with pin out signaling. This is the place we got stuck. Does the one white wire from charger DC/DC converter splice into a second white wire in the harness and then to pins A and B?
(Just to make sure)
A real DCI will have two groups of wires for output. Make sure you don’t mix them up! One of them is charger out (+72v - usually 12ga) and the other is +12v (usually 18 ga).
Yes, the white (switched) output splits off the same wire in the harness as does the black. One wire will go to J4 and the other goes to ChassGnd.
(As noted)
One wire is +12v constant, and the other is the enable wire (comes from key) which switches on the white output wire(s) for the accessories. When enable is removed, the DC Converter continues power on the switched legs for a bit (maybe 30 sec?). Don’t be confused by this.
You won’t have an 72v orange wire in J4. Your converter gets power from the supply inputs (it was a convenient pic I had at hand).
can you post a picture of the charger plugs and I can tell you how to wire. If it is the version I think you have, you will need to hook up more than the 4 wires to get it to work.
Yes, external DC Converters (Surepower units) use this wire.
The DC-DCI cars this orange wire (E) is missing.
(Mental note: I should go track down where the Surepower unit picks up B- but I bet is is one of the loose wires down on the shunt.)
The colors change too. That is why I referred to wire position first.
That looks correct minus the second black wire. From our photo it looks like that black wire was pinned to E and may have gone to chassis but that doesn’t make sense if Pin E is for +72v. I’ll see if there is a better photo angle to be sure. Unfortunately I came into this project after the initial disassembly / rebuild had begun and did not have the opportunity to go through everything in the “as purchased” state.
It has been a long road, during which I have been dealing with serious ankle injuries that made it nearly impossible to get arround, but we were able to finally get the E6 up and running. 1) the Delta Q was not what we thought and did not have a dc/dc converter. We purchased a separate converter. 2) the wiring had to be bypassed/modified to get the converter enabled and the charger to charge by wiring the key switch differently. We had everything working and driving well when the motor that had been in water originally decided to fry itself. Corrosion inside the windings etc caused a catastrophic failure.
Now I have a new question.
Can I use a ride for fun model # 170-501-0002D electric motor with no shunt to replace a GE Motors & industrial Systems model # 5BC49JB1164 electric motor with shunt on a 2014 72v Gem e6 cart without having to change the motor controller and rewire the harness again?
The Ride for fun is a 72v, amps: 95/8, rpm: 4950, hp: 7.5, duty: S2-30min, NO shunt motor
Yes you can swap the motor.
No. They won’t be the same .
The R$F is actually a D&D Systems motor with a different sticker
HP ratings on these motors dont tell the whole story
D&D makes good motors but that one may not be the ideal one and may be overloaded in the e6
My recommendation is contact D&D directly and ask for the “torque motor” for an e6 or eLXD. Or maybe @Old_Houseboater has a refurbished AMD Black that rivals the GE. At one time @LithiumGods had some BFGMs for sale too (Big Farking Gem Motors)
Just re-read the duty cycles, yeah, good idea, wrong D&D.. You may cook that thing in an e6
Thank you for the information on the swap idea. We were able to source a “new” rebuilt motor better suited to the E6. The original was not worth trying to rebuild. With the new motor installed and the updates we made to the enable, key switch wiring, and new dc/dc converter the Gem is running better than designed. It hits around 17ish mph in low and 30ish in high. Very surprising. We monitor the battery pack in real time with a digital meter we installed and can watch the status of charge and draw down under acceleration and cruising. All in all the project was a great success for a couple of thousand invested along with a lot of labor and hair pulling to figure out the original wiring from the manual and the strange wiring that had been previously modified (not well).
Nice Job. 5 months for a complete rebuild on a flood car doesn’t sound too bad to me. Feel free to post up a pic of the finished project now all bright and shiny to close out this topic. It might also inspire others to see that it can be done. Change the subject line to include “flood car rebuild” so it is easier to find.
Is your new motor fan cooled? That is the main thing I would look for.
If no, then monitor your motor temps. Depending on how this car will be used, you might be OK without it.
If you made any changes to the factory wiring, think about labeling those wires for the next guy to follow. Otherwise, time is wasted on what the heck is going on.
