2009 Rear Wheel Cylinder
Anyone know a part number for the rear cylinders and brake pads on an 09 E4. Started leaking after removing to fix the lug studs.
While I am there I will swap out the pads also.
Seriously, no one has a part #???
Disregard, I Found it…
Will you please share the info? I also need them.
http://www.nevaccessories.com/Brakes-and-Bearings/products/91/0/4
I ordered from NEV Accessories. $24ea plus freight… They were in stock and I should have them by mid next week.
Cylinder 0611-00203
Brake Shoes 0311-00833 and 0311-00834
I bought them at NEV Accessories online, pretty good price
Thanks for the information.
There are ridiculously easy to swap out. Didn’t have to pull the shoes, Removed the drums, pulled the 2 bolts, removed the line and bleeder nipple and pushed the old ones out, dropped the new ones in and was done in about 20 for both sides. Had to really clean the pads with brake clean since one side leaked. And before anyone starts (I KNOW its not recommended) but its still a GEM not a race Vette.
Brakes will slam you into the dash now and they no longer drag at all. Added miles to my travel ability…Worth every penny.
