Looking for someone to take over the throttle business.
I gave it away several times but nobody runs with it.
Several methods available. @ScottyD@AssyRequired
I found that I can’t do it all.
Also may need someone to build the 2016+ conversion harnesses if it gets to be more than onesee twosie.
I have 50 controllers and would like to supply them.
Do you still have a Saturn throttle there?
The external switch may make more sense.
With proper documentation, I can sell, switch only. The pigtail isnot needed. Only 3 wires to tie into the gem harness.
It will also repair an oem throttle faulty fs1 circuit.
Here are instructions, i have a couple custom hall effect switches in stock. $50.
If all gems use standard wire colors this should be an easy diy project.
See greyed out gem colors.
Dark green/violet splice in brown from switch. +5 volts
Orange/black cut and connect harness wire to blue. B-
Orange/yellow cut and connect harness wire to black. Fs1
That’s it.
Switch comes with led indicator to show operational position.
Made a throttle tester at one time. I may have sold it or it may be hidden here someplace. @grant did a review of it.
Take me an hour to whip one up. (My mechanic charges a $150 an hour.) My so called retirment time may be worth as much.
