Just wanted to let you know that I was able to use parts from a dorman 699-100 throttle pedal switch ($70) on eBay,to repair my 2008 gem throttle pedal,used the plastic arm inside the switch with the contacts on it,had to relocate one of the contacts and cleaned my circuit board,reassembled and so far works perfect
Nice- Did you take pics? Post them here.
Does the dorman part also have the NO contacts in it along with the resistor track?
Did car harness connector also plug right up?
What is the airspeed velocity of an unladen swallow?
I have many questions…
The “switch” is also a track. The brush is off the track until the armature moves. The arms all look pretty similar, but i only found one dorman that uses the same circuit board switch.
