Can someone tell me exactly what the micro update fixes? I’m still having issues with my charger only saying I’m charged 75% after 3 day of being plugged in. I have 1 month old new Trojan batteries, the old battery pack did the same thing said 75%.specific gravity is around 1.2 after charging.
The light cycles like it should red blinking, red, yellow, green…but still only 75-80 percent.
The only issues that I can find that could possibly fix it is
Ground broke off at plug in on gem
Looks like someone removed temp sensor
Chargers is bad or needs updating
the temp sensor does make a difference . the sensor well tell the charger to adjust charging voltage . don’t know when missing is it well charge higher or lower . I would get one .
you might want to put a voltmeter on a battery while charging and see what its doing.
batteries are so expensive, having your charger working properly is important .
start with hooking up a sensor and see if that helps
elcon is known for taking a loooooong time to get chargers back .
I bought a second one , sent it in , then sold mine when I got the upgeaded one back
Thanks kinghappy. I will definitely order a new one. Before I do, can you confirm that the temp sensor should be back by the rear batteries and connected to 3 wires…a blue, green/yellow and tan wires that look like they are coming out of a cord jacket within the rear wiring harness? I may need some help with a picture or something of how things are assembled if that is indeed the part that is missing on the car.
The answer is it charges normally. The temperature probe and the remote charge indicator light are supplied as a package and plug into the top of the charger. Neither is required for normal operation.
2002 E285 2 Seater w/ Zivan charger - I had a problem where my temp sensor was saying the batteries where too hot. This was while the outside temp was in the 50’s and immediately after plugging in to charge. With Rodney’s advice, I disconnected the sensor (which sat between the front batteries). The charger has worked great since. In the process, I lost the dash charging indicator, but it hasn’t been an issue.
