Thank Rodney for that!:o
He told me KISS.
So I added the single wire.
Thank you for feedback. That verifies the test jig.
He told me KISS.
I would like to make my own 8-12 pin adapter. Do you have part numbers for the connectors?
They are “AMP” multi-lock series. The supplier that you use for electronics should have them.
You will have to pick the number of pins needed.
I can supply more information if you email or pm me.
Also can help with programming cables and sw to monitor controller functions.
Thanks for the lead. I think I found them on Mouser:
12 pin connector plug 175965-2, Mouser 571-175965-2 (T2 connector)
Pins 173681-1, Mouser 571-173681-1
8 pin receptacle 174044-2, Mouser 571-1740442 (T1 harness)
Female crimp connectors 175180-1, Mouser 571-175180-1
Refer to the picture in #18.
Have not found a free hanging female plug.
Use a pcb mount socket with leads soldered on and shrink tube.
Let me know if you find one.
Look up Mouser 571-1740442. I don’t have one in hand yet but it looks like a free hanging plug (mounting style: wire). It uses crimp-on female connectors. I could not find this at Digikey, but Mouser has them
[quote=Inwo;32657]Refer to the picture in #18.
Let me know if you find one.[/quote]
There is confusion between what is called M or F.
I believe you need a M. F socket but M pins.
Look at this example.
571-175973-2
If I were to make a lot of them, I would use and 4 X 2 row pluged into the solder pins.
You lost me on this one.
Factory supplied units have a 8 pin female and a 12 male plug on a 12 inch dongle
Don’t understand the picture
KISS
It’s confusing, as the 8p female is a male. By part description. What we call “female” has male pins.
I know that but what are you showing in the picture? Not anything like the stock dongle. Can you show it as installed?
Picture of the ones I made. post 18
My original suggestion is indeed the wrong gender. To clarify:
T1 controller has an 8 pin “cap” (AMP term) with male pins, and the wiring harness has an 8 pin “plug” with female contacts.
I need a 12 pin plug to connect to the T2 motor controller, with female contacts, and a 8 pin cap to connect to the wiring harness, with male pins.
I now believe the correct two parts are:
12 pin plug, 175965-2, Mouser 571-175965-2
8 pin cap, 368191-2, Mouser 571-368191-2
The 3D CAD model for this latter part looks a bit odd, but from the drawings and specs it appears to be correct. This uses crimp wire terminals, not through hole solder pins.
This connector family is quite confusing, and Mouser offers two other similar parts, so I am still not 100% sure.
Were awaiting a picture of the finished product
Did you find pins? It looks like a protective “cap” only.
This shows pin holes.
571-178455-1
For a one time use, the 8pins could be installed in the 12p housing.
