Thank you, Larry…
Why do I want to do this? Because it’s there!
No, seriously. I’ve looked at a number of e-bikes on the Internet and they do wonderful things and they are very expensive. But then comes the clincher - 30-50 mile range with a 4-6 hour recharge time. That’s great if you you’ll never want to hit the open road and actually go somewhere.
Anyone who has ever extensively ridden a bike knows what it’s like to get on a flat, level straightaway. You get a goodly pace going and you feel as though you could keep it up forever. It would be great if you could leisurely pedal like that on any incline, uphill or downhill.
If you were to raise the back end of your bike and get on it and start pedaling, it would be very easy to pedal. Would it really be that much harder pedaling to simply turn a generator? The one thing I do know about generators is that the faster they spin, the greater the electrical output. I have no idea how much output would be needed to power a bicycle motor. I don’t know if 10,000 RPM is insufficient or if it would burn up the motor. For all I know, maybe 2,000 RPM is all that is required, in which case we could eliminate one of the sprocket sets.
I also have no idea what the effort would be in pedaling four sprockets lined up. I’m guessing it wouldn’t be that difficult, certainly not as difficult as pedaling a bike up a steep hill - maybe. I suppose I’d have to actually put together such a setup and find out.
I have seen youtube videos where people have converted their bikes into generator drivers. The back ends of the bikes are up and the rear wheel is connected to a generator with a belt. The pedaling required is fairly easy. I’m thinking, “Why not connect that generator to a motor on a bike?”
And if the generator needs to turn faster than one can pedal, then throw in a couple more sprockets so that the speed increases exponentially.
So, anyway, in my ideal world, such a set up as I’ve shown would enable me to pedal at a comfortable, consistent rate whether I’m on a level surface or climbing a hill because all I’d be doing is turning a generator and the effort would be the same. Granted, I’d go a bit slower up a hill because of gravity, but, again, the effort put into pedaling wouldn’t change. I’d also be able to go as far as I want to without “range anxiety”, and I’d be doing so under my own steam with some assist.
Welcome to my ideal world.
BTW, I sketched that first drawing by hand. The second one I did on a free program called “DraftSight”, which is essentially AutoCAD without all the bells and whistles.
