I would like to know if anybody has attempted to do either of the following for an EV conversion, because my research hasn’t said anything about either so far, and they both seem theoretically possible -
- Use the plates to attach the conversion motor directly to the vehicle’s existing rear-wheel-drive shaft, and then use a switch or toggle housed in the old gear shift spot to control the forward and reverse functions of the motor directly without the use of a clutch or transmission. This would allow you to put the motor lower on the chassis, effectively where the clutch or tranny was, freeing up loads of weight and space for batteries!
and
- Using the existing braking systems in conjunction with electromagnetic coiling and embedding radially-placed ceramic magnets in a custom-machined brake drum, having the effect of a high-amperage generator sufficient to help recharge batteries during operation. I know others have suggested a similar thing and had it shot down because the belief is that a claw pole generator (that’s what it’s called, here’s the patent) would create friction and slow down the drive train, effectively using more power to generate the power than you’re getting back from it. In regard to attaching such a generator directly to the drive shaft or anywhere on the driving axle, I agree totally, but there’s been little talk of using the forward momentum of the large vehicle in conjunction with the non-driving wheels (like the front of my truck, where the brakes are) to accomplish this. First off, I don’t believe that radially-balanced ceramic magnets would create drag or extra friction in the context of the pre-existing brake drums or hubs, right next to the weight of the actual wheels, and what little there is might go to create extra centrifugal force for added forward momentum to counter the friction itself. The generational gain would be totally worth any extra friction, if there was any. Electromagnetic generation coiling in conjunction even with the existing brake pads, combined with a switch connected to the brakes (that would normally be going to a loud vaccuum pump), would activate the pad-coils as a magnet themselves causing the existing brake pads to clamp down on the magnetic drum. I’m not proposing a perpetual motion machine, just a way to gather back some of that forward momentum. If it makes you feel better, you could call them electromagnetic brakes with an added generation feature.
If anybody has taken either of these approaches to electric vehicles so far whatsoever, as in actually done the physical work of building these things, I would appreciate any documentation on either failures or successes. If there exists no such physical test, I’ll just have to build 'em. If you have any reason these two should not be wed, speak now or forever hold your pieces.
