wow i dont think you get it… lol i’ll explain to you how its setup… and i’ll answer all your questions in turn.
say we make this the simplist setup possible… on the air car all it houses is air tanks no generator to produce air…
what it would consist of for a mechanical basis to get it to move is a piston driven motor (just like an ICE but not burning anything), a drive train (nothing to do with air part of it since its just like a normal drive train), and 3 to 4 composit tanks.
with that setup say you have to replace your tanks every 10,000 miles… they will more than likely be a universal part and will simply be unloaded and then reloaded under the car. not a big deal… you do oil changes now to your car every 3,000 miles… so far… i see no big difference…
as far as refilling goes… I have a 65 gallon air compressor in my garage at home (sorry but i have delt with my fair share of compressors) and you would fill individual tanks to an optimum pressure, more than likely by computer, it would go on to the next tank so that it would be very easy to fill (its easier to fill one tank at a time than all 4 to a high pressure)
the air compressor at say a gas station even if it had to be maintained every day… isn’t all that complex… its all “making” the fuel there ON site i could rebuild an air compressor motor in my sleep, they aren’t horibly advanced machines.
[QUOTE=nerys;1821]
How often are you going to have to replace the tanks in your car? Pressure vessels can only take so many “cycles” before they are stressed beyond safe limits (talk to a scuba tank filler for one example of this)[/quote]
answered ^^ up there (for guesses sake, i’ll say 10,000 miles) all depends on the quality of the material for the tanks and the connectors and what not.
[QUOTE=nerys;1821]
To make it worse the nature of an AIR car means mass is even more important than with Electric cars. This means mass of the tanks is an issue so you can not just “make them stronger”[/quote]
air tanks ARE very strong believe it or not, they’ve been using a kevlar/carbonfiber weave that is stronger than the steel and much lighter weight, not to mention MUCH safer as well (wont explode, but instead just simply crack and release pressure in a controlled fashion)
[QUOTE=nerys;1821]
I think air cars are fantastic. If I could get one of those french cars cheap I would take it. but it IS in fact a very simple band aid while we wait for batteries.[/quote]
i dont know about bandaid, but definately has a decent future…
[QUOTE=nerys;1821]
EV’s are virtually ZERO maintenance and in theory designed properly are virtually ever lasting. They should easily more than outlive there owners.[/quote]
you said it “should” BUT the batteries that currently out yet… make it not so. I agree EV’s are great, BUT the construction of them will remain expensive until mass production begins… an air car already has all current technology out there and ready to use. Until electric motors come down in price, and batteries figure out what to do and how to do it properly, then again… for the time being the air car is the way to go. (for the moment)
[QUOTE=nerys;1821]
Magnets are never an ideal solution there heavy delicate and very “short range” in there field effect. You also usually need to semi conduct to really get a good bang for the buck. that requires electricity.[/quote]
ALL depends on what you do with it. if you design something to take advantage of its weight, then your fine. and what do you mean by short range? last time i checked it wasn’t like you could stick a magnet in a box then expect it to move a vehicle somewhere…
electricity is easy to get for a semiconductive magnet
MANY power sources out there.
as far as MY design. you dont know what it consists of yet, so i suggest you wait and see before taking a stance on it.
[QUOTE=nerys;1821]
Also with Air cars AIR is not the fuel ELECTRICITY is. Your just inefficiently transferring the energy from electricity into compressed air. AIR cars will use twice as much electricity as an EV would but thats still 1/3 or better than what a gas car uses and still withing the realm of solar power (selling back to the grid to offset compressor power usage) You can’t afford the solar array to power the compressor directly :-)[/quote]
yes electricity is still technically the fuel, which is the same case for an EV, taking the power from somewhere (grid) to transfer it to batteries to transfer it to an electric motor…
sorry but your statements have no good structure. (not saying you dont make any valid points)
either way, we are taking something from a large power source in some way shape or form, and making it fit a smaller form (either electricity, air, ect) to allow us to use it on a mass scale…
in all honesty… with as much power is needed to get an electric car running and keep it going… you could in the over all scheme of things power an air car for less power.
EV takes a minimum of 1 hour to fill 80% capacity (currently) and thats consistant power leaking into the batteries.
an air car takes about the same ammount of time to fill as gasoline.
[QUOTE=nerys;1821]
The one good thing is you might be able to use the air tank in a “free” air conditioning system since they should get pretty darned cold as you drive the car
(expansion of gas lowers temperature)[/QUOTE]
definately!!!
one more thing to add… I like both EV’s and Air Cars, both have zero emissions, few moving parts, and similar to improved performance of that of current automobiles.
honestly Nerys, i suggest you look into the air car some more i think you will really like the mechanical aspects of it alot.
