Our highest mileage GEM is the 2005, which is approaching 15,000.
In that time we have serviced/replaced:
most of the wheel bearings pressed in
several sets of tires
two sets of steering rack boots
both rear wheel cylinders
drums turned
one side caliper seals
two sets brake pads
all rubber frame bushings (machined from bronze)
rear shocks
battery charger changed to Quick Charge
two charger AC female plugs
motor bearing at transmission
both CV axles
four of six Dekka Gel batteries
added master switch like older GEMs have
DC converter (warranty)
removed heater (very poor range)
both front seats welded cracks
three sets of brake cables
parking brake lever (warranty)
ignition switch
both door cables
both door hinges
both pins for hard doors (machined from stainless)
several cracked windows
two “oil” changes, always dirty
Daniel
