There are probably a few things but when it comes to their personal Gems . All three run the same battery pack . We all have had different packs and have had a lot of fun experimenting . All said and done all 3 of us landed up with … Bolt battery packs . 180 amp hours of high performance Lithium .
These things rock . More range than I can ever use in a day and super fast .
I have 4 sets available . These are not salvage cells buy brand new cells that have not been used . (Probably don’t want to run the serial numbers thru the FBI data base) .
These are one of the easiest installs , no bus bars and they stay tightly balanced . Usually they are $3,500 for a 20s set wired with a bms .
These sets are available for the DIY guy who will screw in his own bms for the lowest price ever . 2,300
20s packs have lots of power and range , this is a 13.3 kilo watt pack . For those that want to go to the max an additional 4s pack is available to go to 24s ( the most a gem can handle) . I will also include reprogramming your DeltaQ charger for lithium , n/c
