Right turn signal indicator not lighting up, has power to it but looks like the bulb failed.
Pulled it out and looks like I need to replace the whole thing…or am I missing something.
If I need the whole assembly where would I find one. I looked in NEV but not finding it there.
I was able to pry the red lens off and found the LED soldier joint had let go on one lead. Didn’t have much solder on it. I was able to make a repair and got it all back together. Working fine for now.
