2002 Gem e825 - I bought 2 of these at auction, replaced batts in one .all is well with this one. the other one only runs in turf mode .! Switch is good I swap it with other one to be sure. Any idea’s ? Both units have had all updates done to them long before I got them. I noticed on the output side of the motor controller 2 wires marked cf1 & cf2 I was going to switch these to see if it would run in road mode! Good Idea ? If it does I would assume motor controller is bad. If It’s bad MC where do I send it to be checked out… Thanks
Related topics
| Topic | Replies | Views | Activity | |
| 2002 Gem Car stuck in turf mode | 4 | 730 | May 7, 2019 | |
| 2002 won't increase speed when switching from turf to run mode. Help please! | 9 | 584 | August 29, 2020 | |
| Gem high range issue | 3 | 873 | February 25, 2015 | |
| Controller programming required for D&D Motor? | 58 | 2171 | May 17, 2020 | |
| Question | 14 | 1768 | November 2, 2014 |
