Truck tires
That’s BS. However, the clip is only on the inside joint not both. I buy all my bearings on Ebay
I found a bearing on ebay.
How about a link to a boot?
Or do you have them?
Gem Car Part C V Half Drive Shaft Boot Kit 1999 to Current Inner or Outer Boots | eBay
You just cut off the portion you don’t need. Use tywraps to secure.
Note I use cheap commercial bearings - about 5 bucks each,on ebay
That makes more sense. Couldn’t see you paying $40.
I don’t have it out to get a number.
http://www.ebay.com/itm/GEM-CAR-PARTS-GLOBAL-ELECTRIC-CAR-WHEEL-BEARING-Higher-Quality-than-OEM-/190881711458?hash=item2c716fc562:g:EsgAAOSwPe1UCfBH&vxp=mtr
[B][U][quote=Inwo;28479]Should have went with the 14s. :([/U][/B]Look
[B]We tried to tell you!.. But NO, you wouldn’t listen :rolleyes:
Just like my ex wife…
Let me know what it is when you take it apart. I don’t have the commercial # for disk brake fronts.
[quote=Rascal;28508][B][U]
[B]We tried to tell you…But NO, You wouldn’t listen![/B] :rolleyes:
Just like my last wife.[/quote]
Actually Fat tires look better with 12"s.
In Daves set up the focus is the tires. It’s a truck and the MACHO shines through with the package
I’d like to lift that puppy.
I did a lot of thinking about it before deciding on the 12s.
Never thought brake clearance would be an issue. I like the look.
Good thing, because I can’t drive it now.:smiley:
[quote=OLD HOUSEBOATER;28510]Actually Fat tires look better with 12"s.
I’d like to lift that puppy.[/quote]
His two pictures on my screen were VERY dark. Hard to see just what was there other than Black rims and a truck bed on the rear pic. The front picture, I could not see much of anything?
[quote=Inwo;28511]I did a lot of thinking about it before deciding on the 12s.
Good thing, because I can’t drive it now.:D[/quote]
[I][/I]That Sucks… Life, If it ain’t one thing its another!
I couldn’t tell (dark pictures) just what you had there other than the black rims. Rodney will get it straightened out for you.
