Hi All,
Both of my front tires are wearing very uneven on my 2002 e825. The outside of the tire is wearing extremely fast compared to inside (see pic).
Has anyone ever experienced this and is there a way to fix it. I have front disc brakes and installed adjustable shocks.
[quote=OLD HOUSEBOATER;31562]Check toe settings and camber.
Sounds like too much toe in.
If wheels have too much positive camber (in at bottom - out at top) it can cause this type of wear. (Rare cause)[/quote]
I must be missing something here. Boatman gives info on checking “Toe In” but it would appear the wear would be caused more by too much Positive Camber (Wheel is out at top and in at the bottom.)
I check the Camber by using a level in Vertical position at wheel hub.
Thanks for all of the info.
I am ignorant when it comes to toe in/out and camber. I always took my cars in when I had tire issues, the gem is not as easy to get to the tire shop.
So I did the measurements and they are:
Front = 49 9/16"
Rear = 50 1/16"
Is this normal or something I need to fix and if so how can I fix it?
I have a manual you had emailed me earlier but like an ■■■■■ I looked under the “Wheels & Tire” chapter 6, so now I am looking at the “Suspension and steering” chapter.
I am assuming that I perform this with the vehicle “Not” on jack stands ?
So I noticed that my front tires are bowed in when looking at them from the front (see Pic). It is more prominent in person than in the pic.
Is this normal or can this also be part of the problem?
You want to bring the wheels together in the rear. Note the 1 turn is a starting point. You will have to fine tune it after the first adjustment. Make sure you mark the tie rod so you can keep track of how much you adjusted.
Make sure you adjust each side equally or your steering wheel will be off center.
You have positive caster. A lot of this is caused because of the excessive toe in.
Go for 1/8 inch of toe in.
If you still have excessive caster after toe adjustment you will have to go thru the caster adjustment I described.
I have a 2005 GEM E4, and the front tires are showing excessive wear on the INSIDE and are splayed in at the top (in at the top out at the bottom), which sounds like the opposite of what this thread has been describing. Presumably, however, the solution is similar but opposite…
Good Morning. I was reading your post and I am having a toe in problem on my 2000 Gem car. Tires wearing rapidly on the outside edge. I would really appreciate if you could send me the pdf on how to adjust the toe and camber
Do you have instructions on how to do this. I did put a washer between the bottom of the backing plate on the lower side of each front wheel and the camber is much better now. But when I back up the camber on top goes inward excessively. When I drive forward it straightens out.
