Correcting negative/positive camber procedure
90% OF THE TIME
EXCESSIVE NEGATIVE OR POSITIVE camber is a result of IMPROPER TOE SETTING. It is NOT due to worn bushings, weak springs etc, To set the toe find a level surface. HAND PUSH THE CAR 8 FEET and set the parking brake. (why) This allows the front end to stabilize and eliminates the affect of power or braking on the “at rest” alignment. Take a 24 inch piece of 2 X 6 and place it against the tire making sure it doesn’t rest against the bulge on the bottom and mark front and rear even with the edge of the tire. with a magic marker. Do the same on the other side. Measure between the marks and this will give your toe reading. Adjust to 0 to 1/8 toe in. If you were more than 1/4 inch off you need to do the 8 foot back and forth bit and measure it again. You might have to do this 3 times or more. When you can push it back and forth and the toe doesn’t change your done.
