I put the new R4fun wheels and tires on my E2 and it changed the camber. Does anyone know how to reset it?
Rudy
- Check your toe. Toe out creates a lot of negative camber. I set my toe to 1/16 to 1/8 toe in.
2 If your toe is ok make sure your shock bushings are good. ( I have them on Ebay)
3 If your ok on the above loosen up the brake assemblies and insert enough washers on the top 2 bolts between the spindle housing and the carrier to straighten them up.
Really not a big deal.
