I am thinking about purchasing 9 packs for 72 batteries total and going 24S 3P for 77 Volts nominal 330 continuous amps, 165AH or 12.672KW. Total cost with shipping will be about $2k
Very good price. Lfp are heavy but 1/2 that of lead.
Not just everyone will be up for the time and engineering needed to properly make 148 connections.
Not counting balance leads to bms.
Matching the cells to work well in series parallel is a daunting task.
12kw for $2k is a great price. Imo
It should perform well. Might not handle max draw, need to test. It will be a tough install. You have exposed connections on both side of battery. You will need to insulate that well. Have you figured out how you will connect the cells?
