Speedo didn’t work and replaced the sensor --now I have speed reading but no distance reading. the clock doesn’t change. Any ideas??? 2013 ES
Hi
are you in e-meter mode ?
TRIP METER/Odometer Switch/E-METER
The trip switch has three functions: (1) toggling between the odometer
and the trip meter; (2) reset the trip meter; (3) change the function of the
speedometer and odometer from miles-per-hour (MPH) to kilometers-perhour
(km/h) and miles to kilometers; (4) toggle between odometer/trip meter
and e-meter, displaying accumulated power consumed from grid, show in
kilowatt hours (KW/HR).
Using the Trip/Odometer Switch/e-meter
- Pressing the trip switch for less than 2 seconds will toggle between the odometer
and trip meter modes on the display. - Pressing the trip switch for 3-9 seconds, while the display is in the trip mode, will
reset the trip meter to zero. (TRIP must be lit on the display- see page 27). - Pressing the trip switch for 10-12 seconds, while the display is in the odometer
mode will change the display functions from MPH to km/h and miles to kilometers
