Same Samsung sdi quality, but now battery enclosed in pvc box…
21x15x7.5""
$̶2̶5̶0̶0̶ Now $1500
21s 94ah 76v nominal 7.2kwh
Price reduced:
21 sdi cells with hardware $1500
Would this work in my 1998 E825? I started with AGMs but am currently running standard wet cells but need replaced. I am looking more at distance than speed. I live on the NC coast so nothing but flat roads. I see Oldhousboater no longer recommends AGMs. I have had the car for 8 or 9 years and it runs well. I replaced the charger with Quick Charge 6 bank that I purchased from Grant West right after I acquired the car. I assume this charger would not work with this setup?
Thanks Okey
It will work with any 72v car.
The question is if it will fit. Dimensions are listed.
I belive it will fit under the hood, but don’t have a test car.
If you are near Grant, he may help wiring battery. I can’t ship it with a bms.
@grantwest
Also check fitment of this one.
Double the capacity. Two modules needed. 19x14x4.5".
Each module is 19x14x4.5" or both combined 19x14x4.5"? $1,000 for each or both?
Each or 19x14x9 stacked. Most likely configuration.
$1000 for both. This is raw battery only. Bms by buyer. This battery would sell as drop-in battery for $3k +.
Or 94ah battery sold 100s for $2750.
My target would be a diy’er or someone near a forum member for support.
@AssyRequired
