RE: LiFePo4 green cells are back $50 per cell
Do you have any of these chevy volt batteries for the ford think conversion or can you tell me what’s needed?
I have 2002 ford think I want to convert, thanks.
I have a few for my own use. I did come up with another set of 25 lifepo4 cells, if you want them.
These are drop in ready. Standard lead charger may work ok. Reprogrammed dq is faster charging.
To use volt. Buy a 16s and a 6s for 22s.
Or 2 pcs 12s. Tapping them back to the voltage you want.
2 sets of the above will double range.
Green batteries are an easy install with better than lead range . Lots have installed them and have been very happy . If you need a much farther extended range than the bolt pack would be good choice . Can you take a picture of battery compartment and dimensions ?
Also where are you located ?
