Hello all,
Is anyone added a radio or a accessory plug like a lighter or USB 12 V outlet to their car? If so what has to happen?
I mean I know our cars are full of batteries all linked together but did you add a separate battery or just feed off of one of them?
Many men have tried …
Tried and failed?
Tried and died.
Check the owners manual, iirc, it shows an extra fuse for aux/stereo. Then you just need to trace the wires. The wiring prints show aux/stereo wiring, again, you just need to find it.
What year is yours? On my 2000 there is a taped back set of wires on the RH side when you remove the top of the dashboard. I can’t recall the wiring colors but they were the only wires with male and female spade terminals that were not connected to anything. They are intended for 12V accessories.
2002 so i assume i would have them too. Thanks for the tip. Ill give them a search.
why fail? Meaning many could not add anything? Or that when they did it blew up something else? or?
(he was quoting from the movie Dune)
(He does this often)
