Cart shudders when starting from stop - after its barely moving every things fine.
This is not the typical bad battery shudder but only when starting out normally.
Help !
TXT Freedom Cart non DCS
Help !
He never figured it out. Sold it. Buyer couldn’t feel it.
My 2001 e825 shudders upon startup but smooths out, it seems to surge a little while cruising. Any ideas.
jpeppenger
Answered in previous post
Which previous post?
[quote=OLD HOUSEBOATER;17625]Cart shudders when starting from stop - after its barely moving every things fine.
Help !
TXT Freedom Cart non DCS[/quote]
I took my motor out and cleaned and reinstalled. My e825 still buckles and shudders and surges when at high speeds. any ideas?
1 Does it still stutter when starting out?
2 If yes could still be a motor problem - check for open commutator segments
3 If no, could be programming problem - has any programming been done since the last time it was running properly?
4 Controller problem
5 if possible try another motor.
This exact problem has happened to me a couple of months ago after a program change. I could not get it back, I swapped motors with my other cart and the problem went away. Both carts run perfectly. (5 hp motor T1 controller)
very strange, the motor looked fine but what do I know, will have to research this further. I think I hear thud or something when coasting but not really sure. thanks million
You have 2 posted in 2 areas on the same subject. Suggest you delete one of them. Its confusing when we sign in on recent posts.
