Wondering if the roof on a 2016 E4 can be swapped to the new clear panoramic version Polaris offers?
Thoughts?
Thoughts?
I have checked on the price of a Clear roof for a 2022 E6 that was damaged. Interesting, it is only about $50 more than the white aluminum one costing around $650. But the cost from the factory on a new Build Gem is $1100. The problem may be that it lies in the tubular channels that travel the width of the GEM. If it lays on top with sealant, that would be a piece a cake to change. But if you need to separate the roof struts, it would be a problem. I too like the look of the clear roof. Will return to this post if I end up replacing the roof.
Sounds like you were quoting part + installation or just the part and you added that installation could be difficult as an aside notice?
If you are wanting to keep it looking cherry then ya, gonna need a full roof replacement for big bucks.
If not so big a deal it’s cherry but still looking good, how about cutting a hole(rounded corners) across most of the width to remove the broken section and then using UV cured optical grade glue and glue down a flat sheet of acrylic over the hole. Maybe a 2" overlap.  The glue is not cheap and you might have to practice to get it bubble free but should be way cheaper than a complete roof replacement.
