I replaced the charger and now the plug symbol on cluster doesn’t show up while plugged in but it does when unplugged? The cluster does continue to click when unplugged. The charger indicates that is charging and or fully charged.
Key on and I’m not get the click under the seat anymore, no pedal response.
Check main fuse under seat.
The charge inhibit wire (green/black wire) should be grounded when the charger isn’t plugged in and open when plugged in. The charger sends the signal. Any voltage on that wire will fry a resistor in the cluster. Most chargers send a voltage signal instead of a ground signal for that circuit. A lot of people just run the charge inhibit wire from the cluster to battery #1 ground to bypass it.
