I have a 2001 e825 (?) got power to lights horn wipers but not power to insterment panel won’t go.
Battires fully charged
[QUOTE=mwsts@bellsouth.net;12815]I have a 2001 e825 (?) got power to lights horn wipers but not power to insterment panel won’t go.
Battires fully charged[/QUOTE]
try checking the connector it sounds like it isn’t fully connected also check the fuses.
wich connector… I checked the fuses under the hood
The connector that connects the dash to the power.
[QUOTE=FEUS;12820]The connector that connects the dash to the power.[/QUOTE]
I’m going to Alabama to get it this week end an i’ll try that.
I’ll let you know what happens
Check the DC convertor and its fuses under the dash. You should have 72 volts going in and 12 volts comming out.
Daniel
I’ll try that. It’s in Alabama an I’m going to try to get it this weekend.
Will let you know what happens.
