Hallo i have a problem on my GME E 825 the display want not light up and will not drive
The battery all new and I
have 74 volt on the top and Boden to the controller the main relay have also 74 V on the fuse it’s not clicking wen I turn the key i hope of helping thanks
See this thing? This is your ACC Relay/Timer.
Look for 12v on the Org/Gray wire. (Confirm → Y/N?)
(Reference Frame Gnd)
If Yes-
You should also find 12v on the Green wire when you switch the KeyON (Confirm → Y/N?)
Also - post one more pic of the same area including the item to the right next to the one I posted
