Almost ready for prime time.
Grant has volunteered to test.
This one-off seems ready to ship. Keep making last minute changes.
ver.3 gives ~ 20% boost in speed limit . Not field programmable. Set up per customer request. 1/16 to 15/16 This one is 13/16. ie. 13mph reading is actually 16mph.
Ver3 needs no adjustment. Raises speed limit ~20%
Limit still in play.
Ver2 has pot to adjust speedometer changeover point.
I have it set to about 22mph. There is no limit unless it is adjusted above 25mph. This could be done remotely or with a switch.
Speedometer is correct to set point.
The electronic motor magnet modification, works stand-alone for speed increase, or with options.
Got a few samples of accessory products today.
Here is a Tachometer, Speedometer, Motor temp display.
And mock-up of a Tach, Speedo, with Rodney’s volt/amp meter.
The tach and speedometer would plug into pre-programmed circuit board.
Temperature unit comes with sensor.
Volt/Amp needs wiring to battery and 12v auxiliary power from inverter.
Rodney knows all the do’s and don’ts to make this a nice option.
Here is hacked hour-meter/tachometer in action.
Just the top showing 6,000 rpm. Tested to 12,000 rpm.
This will work on any motor using hall sensor, not just Gems.
Rodney, this is self powered. No isolation problems.
It does need divide-by-n circuit to show rpm and mph.
Grant, is this better than big led version?
No progress with cheap wireless bicycle computer. Erratic!
If you return early version, I’ll get you an update.
