The older machines sometimes develop negative camber. This has a few causes.
- Toe out. This happens with age and is not noticed by the owner. Not considered by a lot of people.
2 Displaced rubber in strut bushings. Normal with age.
3 Top strut mounting displaced upward. Normal with age
Remedies
1 Adjust toe to 1/16 to 1/8 inward.
- Press out the bushings and turn them over 180 degrees. This will give you 5 more years and costs you nothing.
3 Drill top shock mounting holes lower. Leave as much metal between old and new holes as possible. Also make sure shock doesn’t touch motor.
What say you?
