Yeah, I figured I was gonna open a small can of worms there. That’s kinda why I wrote “equivalent”. Everyone seems to focus so much on hp and not on torque. It’s like nitrous kits. They are rated as 300, 350, 500, etc HORSEPOWER kits, but what they really make is torque. I know a guy that used to run around on the street with short 25 inch dia. tires on his Camaro, but then when he got a race, he switch out to some monster tall slicks. He knew that the nitrous was going to give him a better holeshot due to the torque increase so that’s why he ran the tall tires - higher gear ratio.
Zombie’s “low” hp rating with HIGH torque rating could explain the slightly lower trap speeds for ETs in the low 12s. From I remember a convention ICE car that ran low 12s would see trap speeds more like 112 - 115mph indicating more top end grunt. When it comes to it though, on the street torque is king.
I’ll rephrase by saying, I’d like to be able to get my Camaro into the 12s. Around 12.80 would be nice. Faster would be nicer, but I’m sure that’s where it will start to hurt my range if I want to stay under a certain weight. My Camaro with it’s original 350 ran a low to mid 14 so high 12s and 60 mile range would be enough for me. If I could go 100 miles on a charge, but had to goto a less powerful motor thus dropping me into the low 13s to do it I’d be happy. My main challenge will be getting the car in at or under the original curb weight- 3000lbs. Can you say “steady diet of fiberglass and possibly lexan”?
Any idea how much Wayland’s power system weighs? I figure a Warp11 and the same battery setup might do fairly well.
I’m gonna have to start a planning thread for my car.
Cheers
[QUOTE=Jack the R;275]Keep in mind that electric motors produce more torque than horsepower, and it’s all available at 0 rpm.
The two motors White Zombie uses are advertised as making 20 hp each and yet White Zombie is making 770 lb/ft of torque (available instantaneously) and eating Vipers (I think that’s the 2nd gen 500 HP Viper too).
IIRC Killacycle’s pack is 160 lbs. I’m guessing the driver is 150 or more and the frame/tires/wheels/etc are another 150 at least. That puts the batteries in the 30% range.
Again, IIRC, White Zombie is around 50% battery by weight (more machine, less man). Zombie uses Hawker Aero batteries though which are probably not anywhere near as good as the nanotech A123 cells Killacycle uses.
I don’t know what the Zombie’s range is. Wayland has another Datsun which gets 20-25 miles reliably but it doesn’t appear to be set up as well as the Zombie is. I wouldn’t be surprised if White Zombie could go 60 miles on a full charge. I don’t think it would be 60 miles of spirited driving though.[/QUOTE]
