Servo motors typically have a lot more horsepower per size. Some even use rare earth magnets. They are also inverter duty rated, and many indramat servos are liquid cooled. If I do the indramat motor, I’d use the indramat drive and run 300 vdc to the bus. I really love the formfactor of the curtis controller though. Max speed on the indramat is 3000 I think. If I can find a 6 pole 1200 rpm motor that would be nice. I get the low end torque, and can still spin it to 3500 rpm.
I’d be willing to do pack voltage up to 300 if I can find a suitable AC Motor. I think using the 84v curtis 1238 ac controller is now out of the question since I can’t find a suitable motor. There is one guy local to me who is using these curtis controllers with two motors on a fiero. Im hoping to meet up with him to see what he’s done, he’s out of the country right now. He is using motors from a dyno.
Im looking to do a proof of concept right now with my land rover discovery. The disco is all aluminum, has a ladder chassis which can support tons of weight. I have heavy duty springs on it. Im planning on keeping the stock aluminum v8, that will run the front wheels. I’ll remove the rear driveshaft and direct drive an electric motor to the rear diff. I can easily charge the batteries by dynamic braking the rear while driving the front with gas. This is the reason I want good regen ability.
I only plan to use electric in stop and go traffic, and maybe accel me to 25mph. again, this is just a proof of concept. The rover weighs in at 4000lbs, but it can carry alot of weight in batteries. Has big disc brakes on all four, and tires that can handle 65 psi and the heavy load.
The dc option is obviously the easier option, and I may still go that route. There are army surplus dc generators with separate field windings rated 30 horse continuous, 70 peak, they sell for around $650. Problem is they are rated 115vdc. No simple way to drive it. An industrial drive system would require AC for the SCRs to fire. LOL, so basically I’d need a ac drive to convert dc to ac, then use the ac to drive the dc drive to run the dc motor. SCR would require a decent sine wave to work properly, and the regen feature of the drive would probably not work doing this.
I could try to build a constant current powersupply or pwm? Motor is rated 200A. If I want to over drive it to get peak hp, I’d probably have to go to 200vdc. And then, still no regen
Since im direct driving the driveshaft, I’d like to find a 2:1 reducer. I could do belts, but it would be nice to find a proper gearbox to bolt on the face of the motor. I was also thinking of a pneumatic or magnetic clutch to disengage the electric motor above 25mph (or whatever max rpm ends up being on the motor). I already have on board air on the rover.
The diff ratio is 3:8, there is also a 4.11 available. The 3.8:1 brings me to 3200 rpm at 85 mph. a 4:1 would get me tons of torque and max speed of 20 something mph.
So to answer your questions:
For my proof of concept:
Weight 4,500 lbs
Type: land rover discovery
Max speed: 85mph with ice
Payload: its rated to tow a 7700lb trailer.
Gross vehicle weight: 6,000 lbs
After my proof of concept, I would like to do a TDI passat or a4/a6 (maybe even a wagon). The car is front wheel drive, but they do make a quattro version. I’d take the rear suspension from the quattro and drive the rear wheels.
